Hard Pipe Kit??
Hard Pipe Kit??
I went searching through the old threads because I couldnt remember who made these hard pipe kits.. I found 2 companies... 1 was Huntley Racing and they are no longer around from what I see. The second company was Mind Over Motorsport but so far have not received a response.
Does anyone have an alternate source for a set of hard pipes for the 993?? I would make my own custom set, but, right now I dont have the time so I would prefer to purchase something that already exists.
Yes. Exactly.
This is my 4th 993TT, and the boost pressure hoses are one of the weakest links when you run higher power.. I dont want to invest any money in revised hoses, so I wanted to grab the hard pipe kit right away. Problem is, I cant find them..
Originally Posted by Barney1
Is this for the boost pressure hoses ??
Heat soak isnt an issue.. Whatever I buy, I will have coated with a 2200F thermobaric coating. And if I really feel the need, I'll wrap them in an insulating blanket.
Originally Posted by AndyT
they will heat soak and cause higher intake air temps. just use the orange ended ones with better clamps.
