Urgent: Will a 993 Turbo engine fit a 993RS??
Hello,
I have a 1995 993 RS Clubsport and would like to upgrade the power of the car. One option is to source and install a 993 turbo engine. Having now found one I am wondering if it is possible to fit this engine from a 1997 993 turbo which has the standard 408 bhp.
I am so far only aware of the need to change to a GT2 style rear spoiler. What other modifications are needed? Will my RS G50/32 gearbox fit to the Trubo engine and can it handle the power and the torque of the std. engine. What are the power/torque tollerances of the standard g50/32 gearbox.
The engine is "turnkey" including all ancillaries such as wiring loom etc.
All input is most welcome.
Thank you
Thank you
Jonas, yes you can and I think it is the best bang for the buck for anyone wanting to get more power from his N/A car. It will take some work but nothing that an experienced mechanic cannot do. Make sure you get the wiring harness and ECU with it, it will make your life easier I am told.
With the weight of your car and a stock TT motor, your car will be extremely fast.
Your stock G50/32 can withstand perfectly well the torque of the stock TT engine, it is a straightforward bolt-on, you will need a clutch change though.
More technically experienced guys will chime in hopefully.
Thanks for the input. A Swedish friend of mine Magnus told me to seek input from you. Once again thanks. My car now weighs 1200 kg with the original doors which are planned to be replaced with similar plastic items but it seems difficult to find them here in Sweden and Cargraphics are simply are ripoff at €2500+.
Question:
1. What do you see as a fair value for a low mileage [<10000 miles] stock engine with all ancilliaries included?
2. Are there any changes in the engine this being a Euro 1997 car/engine. [I know updates to the gearbox where made in 1997 as an example].
3. Would you recommend using a secondary oil cooler with the standard 408 engine?
Thanks for you replies so far.
Originally Posted by Jonas Ribbelov
Jean,
Thanks for the input. A friend of mine Magnus told me to seek input from you. Once again thanks. My car now weighs 1200 kg with the original doors which are planned to be replaced with similar plastic items but it seems difficult to find them here in Sweden and Cargraphics are simply are ripoff at €2500+.
Question:
Question:
I am not a mechanic or tuner or anywhere close to being one, so whatever I tell you needs to be verified by the people in the know.
For the doors, try DP Motorsports in Germany, they have fantastic stuff, or for the real stuff, you cantry Gert, at www.carnewal.com but expect to pay the price for great the quality stuff he sells.
1- I sold sometime back a full FVD engine with 540HP upgrade including Cargraphic intercooler, ECU, etc.. for 25K USD, you should get a stock engine with low mileage for around 20k USD Max. if you wait and look closely, don't go to the famous dismantlers
2- No changes to the engine, maybe some minor stuff, the ECU was changed but nothing to worry about. The gearbox update in 1997 was a stronger mainshaft "it seems", but nothing to write home about, they still bend if you launch hard.
3- I would not anticipate the need for an extra oil cooler ( it is Sweden afterall! ) for a stock engine, but you can wait and see once you run the car.
Others might have different opinions
Keep us posted and feel free to ask any questions.
Cheers
or you can buy my car
1997 993 TT, 50k miles but nearly everything has been replaced or rebuilt.
Interior
Recaro SPG Pro Racer Hans Driver seat with sliders( new 2007 )
Recaro SPG Passenger side seat with sliders
Schroth Profi 6 point harnesses (red)
Momo Porsche SuperCup Steering Wheel
TC snap off steering wheel hub horn function retained
Safety Devices Full Roll Cage
Lower Dash removed, Factory RS knee pad installed for ease of getting in and out of the car
Brey Kraus Seat Back brace
Halon Fire extinguisher and BK mount
SFI Rollbar padding
RS door panels
RS parking brake handle
930 style manual Boost gauge (clock still connected behind the dash)
RS console package tray replaces cassette holder.
Rear wiper delete
Airbag removed on the a passenger side
No airbag on the driver’s side
Hot lap timer with smaller display unit.
Radio removed for 2 way Motorola base station unit 30 watt
Rennline RSR floorboard on the drivers side along with Ultimate Pedals and dead pedal
Schroth Window Net
RS style rear carpet kit. Replaces rear leather deck and seat padding (40 pounds of crap)
Wired for 2 way radios, (roof mount antenna included)
Kokelyn shift ****
Suspension
Porsche RSR Bilstein shocks revalved by Bilstein to match higher spring rates
Hypercoil 900 – 600 lb springs
MODE Design camber plate / monoball uppers in the rear
ERP monoball / camber plates up front
Factory Motorsports strut tower brace
RS rear adjustable sway bar (3 way)
RS 5 way adj front sway bar
ERP Front lower control arm monoballs (replaced the OEM rubber ones)
ERP rear adjustable links, Kinematic, tow, camber, and monoballs in lower control arm
ERP solid Carriage Mounts
GT2 Evo Uprights
ERP bump steer kit
New wheel bearings all around
Engine
RS Lightweight Flywheel
RS pressure plate
GT2 clutch disc
WEVO motor mounts
BMC air filter
GT2 Evo dump pipes (no cats) have originals still
Billet bypass valves
Clewett Serpentine Belt kit
OEM Headers, heater boxing removed
GT2 oil cooler (driver’s side)
New plugs, cap, rotor, wires, filters, seals, virtually everything without pulling the heads was replaced
Leakdown of less than 2% across all cylinders
Injectors flowed and matched
All sensors replaced
FVD programming for EVO pipes
turbos rebuilt by Durabilt 2007 zero miles
All sheet metal bead blasted and powder coated 2007
Weight savings
Heat removed in the engine bay
AC condenser and lines out (Compressor still there for PCA CR rules )
Crash bumpers removed for weight savings
Rear seats removed for cage fitment
Brakes
Pagid Black / Black pads new
Fischer Stainless lines
Pentosin racing brake fluid fresh
Body
Euro front bumper cover Factory part
Euro rear bumper cover Factory part
GT2 Carbon splitter – MA Shaw Designs
Aluminum support plate custom fabricated to stiffen the 3 splitter sections
No fog lights for better flow to the oil coolers
Euro orange corner lights
Amber rear Euro lights, Factory parts
2 sets of BBS Motorsports wheels 18 by 9 and 18 by 11.5
One set in Gold one set Silver
Hooisers R-6 tires 315 and 245
996 OEM hollow spokes with street Kuhmos, never used
Custom fabricated tow hooks front and rear.
Interior
SFI Rollbar padding
RS door panels
Rear wiper delete
Schroth Window Net
Kokelyn shift ****
Suspension
GT2 Evo Uprights
ERP bump steer kit
Engine
RS pressure plate
GT2 clutch disc
WEVO motor mounts
BMC air filter
Weight savings
Brakes
Body
Hi Jonas,
perhaps a silly question but why don't you just carry out a twin turbo conversion to your motor ?. Or is the 993 TT motor that cheap ?. You are in the write part of the world so talk to Micke Svens. Here is his link.
http://www.spezialmotorer.com/
regards, Graeme
regards, Graeme
Originally Posted by LA964RS
I have a 993TT in a 964!
If you are goin to do this...seriously think about doing it with a 996TT...much better starting spot for mods...and IT CAN BE DONE!
Originally Posted by TomF
What a ba$tard child that would be- a 996TT water-pumper in the pinnacle of Porsche air-cooled engineering, the 993 RS?! That hurt me just to type. Oh the humanity! Please tell me that you were joking...
The 993TT alternative is too an easy alternative not to pursue it...
Can't wait, question is what I will call it GT2 RS
No I think I will stick with the iconic 993 RS. Mind you so far I don't like the look of the GT2 wing from behind the car. Here I think the standard Clubsport wing looks better. This might change though....
You need to start em early, a picture of my daughter learning to drive...
Originally Posted by graeme36s
Hi Jonas,
regards, Graeme
regards, Graeme
It will make a huge hole in the wallet and you'll have the fastest car on the continent. Going to these guys, I think you should really think twice. It's A class tuning and question is if you really need those last HP. If it was free, I wouldn't hesitate a second whom to go to! Micke is sure a great guy and a Porsche lover too.
How's that GT2 of yours doing? Still as adorable as ever?
Hi Rassel,
for one reason or another it did not happen. Not something I wish to share. I'm still looking but the prices seem to be going up and up. Hopefully will have one soon, currently an evo on the near horizon. Spent yesterday at Silverstone on the GP circuit in between rain and shine with a real nice chap who let me loose in his 993 GT2 club sport. Awesome bit of kit which reassured me I was making the right decision.
9M, fabricate billet heads and various other mods to get 400bhp out of the n/a motor, have you considered this? More in keeping with the character of the original car?
As an aside have you seen this RS conversion?
http://www.specialistcarsltd.co.uk/p...SRED993CT3.htm
(Ignore the price it is slightly optimistic, this sold in Germany for substantially less last year.)
