Shoulder harness mounting w/Brey Krause guide bar
I currently have my shoulder harnesses mounted to my Brey Krause harness guide bar (not the big one, just the guide) and I understand that this is not the preferred or recommended setup (though it's pretty common among the zone13 crowd).
So I'm looking for alternatives. Does anyone know if there are spacer and eyelets that make the backseat seatbelt mounts useful for clicking into? Or is there some other simple solution that doesn't involve drilling?
Thanks,
John
Thanks,
John
not safe is more like it. You should attach the shoulder belts to the rear seat belt bolts. Replace teh bolts with eye bolts. These can be found anywhere harnesses are sold . Use the guide bar to" guide " the harnesses ONLY.
If you want to mount the belts to the bar. You need to get the BK Harness truss. That is meant for mounting points. Or a roll bar. A
