Bigger MAF
#32
Brad you have nothing until you show us datalogged runs and proven weight
js911, you too!![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I sincerely commend you for thinking so much outside the box and taking the challenge. Where I differ with you is in thinking that you have discovered the secret of Porsche horsepower and that other highly respected Porsche tuners are inept, you really have ruined it all there.
Let your numbers speak for themselves, put your car to test the proper way, with datalogger and full transparency on weight, and no boost levels and fuel excuses like we often see, and then let's talk about it without any show off.
Trust me I would be the happiest to know that the MAF that my tuner has been using for a long while now (Ford) on others' customers cars, will give me better results than my expensive and not very friendly pressure sensing system. I estimate that I "only" have around 620-640 real Porsche HP at 1.2 Bar based on my 5.6seconds 100-200kph run in this heat. So what happened with your revolutionary twin MAF experiment?
Most of us know TurboKraft, most of us have been around here for a long while now and most of us have seen many Rennlisters come and go with many crazy claims. Remember, everyone's tuner is the best in the world
js911, you too!
#33
Originally Posted by TB993tt
Yeah I seem to recall the "Bob's (Mode Inc) big I/C Garrett turboed engines"........thats right, about 400hp each ?
Only problem is when a car with this spec was plugged into RS Tuning's engine dyno and the Motec Europe race mapper attempted to find the 800hp he couldn't manage more than 600hp......
Mr RS had to hand him a set of RS spec K27EVO units off the shelf which allowed the 800hp to be found, and I won't even go into why "that" 800hp is not the same as RS's "800hp" I suspect you are too far gone
We won't even talk about the power curve with such big turbos
Glad you're happy, but don't dis' people who have built up their reputation the hard way![nono](https://rennlist.com/forums/graemlins/nono.gif)
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
I don't want to dis' any people, I just share my experiments
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
#34
Originally Posted by Acropora
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
I have 700 hp.
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
#35
F=m*a. Send me your datalog where you accelerate with one gear on the flat asphalt, lets say 5th gear from 2000 rpm to 7000 rpm and tell your gearratio for that. Also weight, Cd, frontal area, tire specs and I can show your dyno chart. But I believe, you can also do it yourself. You will surely get more than that 640hp!
Remember, everyone's tuner is the best in the world ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
#36
People have asked pictures privately, so here is one picture from installation.
installation
And here is one test with hot engine, 21 degree, about 1650kg, soft start = no wheel spinning, lazy gear changes. Speed signal is from OBD, refresh rate 4hz.
acceleration
Sorry Jean and TB, I don't have better measurement yet..
installation
acceleration
#37
js911
As I said, it is great that you share your learnings and thank you, honestly.
What I meant by ruining it, is when you make fun of builders with 20+ years of racing and Porsche engine building experience didn't think about slapping a pair of Garretts, and get 700HP, or while having all the Bosch Motorsport engineers almost in their payroll, they did not think about asking for a better MAF that would take them beyond 600 FWHP.
As to your above quote, I find it almost funny to see my exact words repeated by someone else, and being told back to me
Did you get hold of my spreadhseet model by any chance? If not, I would love to send you my logs and then you getting back to me with your graph, even from 5-7k RPMs, at the end of the day this is where peak HP is. We can compare outcomes.
Finally, why do you think that you know better than me my own estimates for my own engine based on my 100-200kph, what is the basis of the calculation? I should usually be optimistic not pessimistic about my numbers![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Keep up the good work about sharing your progress, just be a little more realistic about your claims, and thinking that none of this has been done before dozens of times, that's all.
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
#38
I don't understand why you don't agree that these 993TTs can be tuned easily for over 600 hps. You just need, for example, 2*GT2871R, RS cams, 3.8L, TwinSpark, 3rd fuel pump, good flowing intake and free flowing exhaust system and then the man who can reconfigure stock Motronic for that combination. There is no any magic for that, just simple doing..:
Look at some simple facts. Most recently my tuner's engines powered the conquering Alzen turbo 996 with Bosch factory support. They developed a turbo traction control system for Porsche during the Alzen development.
They built the engine for the EDO 'ring record holding 996tt and the engine for the Cargraphic Tuner GP winning 996RS and 997RS......
You say it is simple, use RS cams ? Well why did RS remove the RS cams and test three different (mechanical) profiles in conjunction with different new hybrid KKK race supplied (yes that is the KKK race dept) turbos on their very expensive engine dyno (same type as used by Ferrari F1) before signing off my lame sub 600hp motor ?
They are fools ? I am being ripped off ? (they didn't charge me any extra for all the testing and time building up and on/off engine dyno)
I accept that 993tt engines can be built and a peak reading of 6XXhp can be gotten but you are not talking about a level of drivability sustainability and reliability that Porsche would sign off.
I don't want to dis' any people, I just share my experiments ![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
I have 700 hp.
#39
If that 6.5 seconds 100-200kph is accurate it is half a second faster than the 542hp RS-tuning 996gt2 with 2wd.
He is way faster than a Turbo R or a CTR2.
I think he is near 600hp - if that is reliable and sustainable or just peak hp we will see.
#40
you make fun of builders with 20+ years of racing and Porsche engine building experience..
If not, I would love to send you my logs and then you getting back to me with your graph, even from 5-7k RPMs, at the end of the day this is where peak HP is. We can compare outcomes. ![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Finally, why do you think that you know better than me my own estimates for my own engine based on my 100-200kph, what is the basis of the calculation? I should usually be optimistic not pessimistic about my numbers ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I just comment that time, 5.6 seconds, for that 100 to 200 kmh acceleration. I doubt that your estimate (620-640hp) isn't enough for that time.. Your car must have more power, like in that Protomotive dyno graph..
#41
I just said what is one possible way to achieve +600 hp or even 700hp
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
and that better IC is not necessary needed for that if only it helps things..
#42
I don't know about your speadsheet model. F=ma is very common equation and also rolling and wind resistanse equations. I know very well these mathematics and physics because I need these in my work..
Yep, just send me your accelerationg data and all needed parameters and I will calculate same power and torque curve than you because these are not your or mine equations or calculations, they are physics laws.
I have a much better and more reliable way to give you an exact dyno chart of your car on the road. Simply if you can send me a 4th. gear (or 5th or 6th) run from 2K RPM up until the rev limiter on an AX22 GPS datalogger. From there I can extract with some formulas the exact flywheel horsepower and torque
Long G: 0.40
Speed: 129 Mph
CD: 0.34
Area: 1.93
Stock 993TT gearbox: 5th gear
Total weight: 3300 lbs
Tires: 305 x 30 x18
![typing](https://rennlist.com/forums/graemlins/yltype.gif)
BTW, your run looks more like a 6.8-6.9 than a 6.5 second run from 100-200kph
#43
Tb. I'm sure RS are without a doubt one of the best in Europe. But you can't discredit the reputable tuners on this side of the pond, Bob being one of them.
#44
Hark and indeed Hail, js.
Some serious claims you postulate.
As one of the lost boys who wasted money on the German way so it seems, I am keen to see real data from your motor via AX22 or the like.
Cheers,
M. Mouse.
Cheers,
M. Mouse.
#45
Originally Posted by biiig-hp
I know for a fact that engine was never quoted to have 800hp by Bob.
