993 TT S front spoiler
I wonder if its possible to restore a TT fitted with a S front spoiler (original Porsche) to standard without to much truble?
I planning to buy one but I don't know how it's attached, screwed or glued or...??
I don't want to destroy anything to much...
Thanx!
/Magnus
Thanx!
/Magnus
On the inside of the sides of the lip spoiler there are two mounting bolts that require holes to drilled into the standard spoiler. Once the lip spoiler is removed you will need to do bodywork to cover those holes. The other attachment points use existing ones. The other concern would be the strength of the two-sided tape or glue used to attach the perimeter of the lip spoiler to the standard spoiler.
