Traffic Pro installed.....
How easy? well for me it was difficult, I had to reconstructed the Factory pre-amp out wiring harness. This took over a week to first get the parts from becker and then figure out the wiring... Rennlisters wer very helpful.
You will need the Becker Removal Keys to get the old radio out.
For a 1997+ 993 the install will take about 1.5 hours.. (2.5 for 95-'96), GPS antenna mounts perfectly under the rear deck leather panel.. hidden... need an antenna extention cable from Becker ~$20 run along the right side behind the panels and under the plastic threshold....
Reverse signal is taken from the VENT control unit.. which is right next to the radio...
On a scale to 1-10, this is a 2.
![](http://www.johnfelker.com/becker/green/189.jpg)
