Location of Bosch DVs
I took off my IC earlier this week b/c after reading about failing by-pass valves I wanted to check the ones on my car.
I can only locate one of them in front of the intake manifold. Does anyone know where the second one is? Isn't there two on this car?
From looking at the routing of the hoses it seems like the return side goes back to the intake right after the MAS but what I don't understand is that the high pressure side hose seems to emerge from the intake manifold which is after the throttle body. That doesn't seem to make sense b/c one would think that the high pressure hose needs to be connected b/t the turbo and the throttle body. Am I missing something?
Thanks in advance.
Thanks in advance.
