air-cond problem..........need help
MY 95 with 60K miles. When turning the air on, it will come on for about 5-10 seconds and then sounds like the fan shuts down but leaving just a high pitched whirling sound and no cold air. Can someone shed some light on this problem?
TIA
TIA
Sorry that I can't help you with your problem, but I really like your screen name.
When I started doing my Driver Education events, I remember they talked about how to drive a 911 through a corner. Just remember these 3 things, they said:
Don't lift
Don't lift
and Don't lift
Jeff
Don't lift
Don't lift
and Don't lift
Jeff
I received the same instructiion at my recent driver education. Once I followed it, I began to understand the capabilities of my car.
Fred
P.S. Your air conditioning dryer should have a sight glass on top. Run the air conditioning and see if there are air bubbles in the glass. If you see them, then you may have a low charge of freon. Have someone add freon and do a leak check at the same time. These vehicle are very sensitive to the amount of freon in the system. This can have a dramatic effect on your air conditioning system cooling capability.
Fred
