Ok, what does a Boost Controler do?
So just so I understand it, k-24 with upgraded injectors and a reprogram on all stock internals and stock ic, in California, will yield about 150 hp more with NO problems?
Rennlist Lifetime Member
No! K24s with a Porsche-tuned ECU gave 450 - a more aggressive tune will get you 480 to 500 max but no way to 550.
doc-porsche, where in SoCal are you. I'm in Ventura county and will be happy to give you a ride once my car is backtogether(should be any day now).
You can get 500fwhp(400awhp) with the 16G protomotive set-up. I'm adding RS CAMs with my engine build but doubt that will really increase to peak HP. Going above 500 flywheel hp is where you need to make some bigger $$$ changes. These aren't like the Water pumpers as faras putting big HP for minimal $$$.
Chad
Chad
