Banana - Next Chapter
Originally Posted by leonsamonas
..my rev limiter is set to 7200rpm and i'm wearing 295/35 rears..
Do you have hydraulic or mechanic lifters?
What size front tires you have?
Originally Posted by Jean
Thanks Leon. Makes perfect sense, this setup should take you to 215mph or so at redline...Very smart combo and choice, congrats...
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Leon
Could be a bit off, but 198mph at 7K RPMs is what normally 285/30s would give you.. A 100RPMs visual difference or margin of error is 3mph less so it is difficult to tell visually..
295/35s are very seriously large tires that give you 5.7% more top speed because of their rolling circumference, exactly the same as if you fitted RUF's taller 6th gear ratio of 0.71 (that they used on the R Turbo and some other).
Were these tires sizes RUF's choice? Kudos to them!
Leon
Were these tires sizes RUF's choice? Kudos to them!![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Originally Posted by TB993tt
Leon
You sure you've got 295/35 rear tyres ? I saw they were Corsas and I thought I saw 285s ? - I can't see any 295/35 on Pirelli web site ?![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
I think we should change your net name to DT...'doubting Toby'
yo, toby have you been smoking dust? I wear pirelli corsa 295's for 1000pct sure on an 11" wheel, in fact you mentioned you were wearing 285 on the same width wheel hence the problem with rolling diameter
I think we should change your net name to DT...'doubting Toby'![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
![Embarrassment](https://rennlist.com/forums/images/smilies/redface.gif)
On the run up to this I researched which manufacturers did 295/35s/285/35s etc.......hence why I didn't think you could get Corsas in the 295/35 combo - I'm obviously wrong
It may amuse you, but prior to Vmax I had the guys from Event tyres (a mobile fitting company) come out and attempt to fit 295/35 PS2 Michelins on my rears - suffice to say they rubbed and I felt a tw&t sending them away without a sale, they thought I was mad
On the run up to this I researched which manufacturers did 295/35s/285/35s etc.......hence why I didn't think you could get Corsas in the 295/35 combo - I'm obviously wrong![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
