Brake Pedal Height
Is there a way to adjust brake pedal height on a TT? Coming from my old C2, the brake pedal runs higher on the Turbo and I'm having to roll my foot over awkwardly to blip the gas on downshifts. I can do it okay in a panic (the Turbo arrives at corners a little sooner than I'm used to), but its not as comfortable as the old car. Thanks.
Robert Goldman
Robert Goldman
Yes you can certainly adjust the brake pedal down. Remove the wood cover and you will see that there is a threaded rod for the pedal. When you adjust it down, you will also have to readjust the brake light microswitch. This is usually the limiting factor in setting the pedal height... You should still be able to get it dwon about an inch which makes it much nicer...
Thanks for the replies and info. Viperbob, you're my hero. The car is out getting its coil overs today, so it'll need a little pedal adjustment and tire scuffing this weekend.
Porsches have wood in them???? Go figure.
