Headers on the way......
I am going to be beta testing some headers. Having seen them I expect good results. If all works out well I am going to arrange a group buy.
I expect to gain HP on the top end.
Any thoughts????
Any thoughts????
Originally Posted by K24madness
Any thoughts????
Apart from looking shiny and nice and smooth inside, what has been promised to you with these new units ?
TB,
I know the factory headers are real restrictive near the outlet. The new set looks real promising. I suspect that top end power will improve with the better breathing. I also expect lower CHT's and EGT's from the reduced back pressure.
The header are available with and without heat exchangers. The set I am beta testing may not have heat. If that turns out to be the case I will just route a 3" SS tube from the rubber boot to the cat pipe and pick up a little heat from that. Since I live in California its not a major issue.
Two different people have offered up the AX22 to allow me to test my car. I will add it to my dyno testing proceedures and see how this next change affects things.
