My 993 TT
#32
Some qestions i have been thinking on here in thailand
The parking brake light will it not light up when the parking brake is ON...
Cruise control how do i set it, is there a light when it's on, my will not work i think, maybe there is a fuse or something...?
#34
Boost Junkie
Originally Posted by Rickard 993 Turbo
The parking brake light will it not light up when the parking brake is ON...?
As to the cruise, there is no light or other indicator. You just activate by pushing the stalk toward the dash (the same direction as you would push the turn signal stalk to turn on your high beams. If it doesn't work, the first things you usually want to check are the switches down in the pedal cluster that work upon brake or clutch actuation to disengage the cruise. You might want to search the main 993 forum - there should be lots more detailed info on this there.
good luck
#35
Cruise - push forward to set, pull back to release, up to accelerate, down to cancel, and no it is not a 996/997/boxter ie. there is no light on the dash. If it doesn't work - check the switch at the clutch pedal. It is a cool system - you engage - it works, you press the clutch - it disengages so you can change gears, and when you release the clutch it re-engages and maintains your speed at the preset speed.
#36
Nice, are you going to modify it or are you a stock type of guy..![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I had a trackmodified 964 Carrera (used in PCS Racing, not by me) before, but that car was hard to live with on the roads. But I am pretty sure that i will do some minor mods in the end the winter
#37
Originally Posted by Rassel
Nice, then we got five Swedish Rennlisters with Black 993 Turbos. ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
#38
Hmm.... no idea actually. But I've seen most of them since 2003. So Perhaps 10-15 black ones? Perhaps more? I have to look it up. Some went to Norway though, but I heard new ones are coming in from Germany from time to time. I've seen two in Stockholm unidentified, perhaps one is yours?
#39
The parking brake light does work so the switch at the parking brake must be broken or miss adjusted
I have tried all the things above with the cruice control and o doesn't work so i will need to check the switches at the pedals when i come home then
#40
#41
Here is more pictures of my car
This is when my friend took it to the swedich registration and did it ready for Swedich roads, car was perfect and didn't have any foults
http://www.zatzy.com/showthread.php?t=245836&page=4
#43
Now i have looked in to this, and you where right the switch for the P light was lose sp i did adjust it and now it work perfect
Same with cruice switch, i was miss adjusted..
