Stage 2 ZC Dyno
I'm posting this for sfl993t4:
"The torque curve is easily seen, unfortunately their dyno is only set up to graph up to 450bhp, but the numbers are in the print out.
The car has the following mods:
Stage 2 ZC Turbos
Larger Injectors (instead of a 5bar FPR) Apexi AVCR boost controller controlling the boost, all other functions are controlled by the Motronic.
The AVCR is set up with two boost levels. Setting 1 is 0.75 Bar and Setting
2 is 1.0 bar.
The car produces 450bhp at 0.75 and 490+ at 1.0 bar.
The car had quite old fuel for the dyno runs (maybe had been in the tank for
3 months) and so it is possible that it would have dyno'd a bit higher with fresh fuel.
Steve"
Stage 2 ZC Turbos
2 is 1.0 bar.
Steve"
