Ignition Maps wanted
Guys
I have just installed an ECU (megasquirt) to control my ignition and get rid of the old EZ69 that controlled it (it broke) i replaced it with this ECU because I am going to EFi very soon and it can control the coil directly and I didnt need to spend $2000 on replacing the contoller.
However before I get the car to the dyno I need to put a 'conservative' ignition map in there - its a 12*12 table of RPM vs Kpa. Geoffrey kindly gave me a stock setup but I would like to see other peoples tables and what engine setup they have so I can get a better feel how different the timings can be, therefore if anyone has an ignition map I would to see it. Also any standard ignition tuning tips for startup etc would be helpful to me.
My setup is:
1994 3.6T
Single plug
K27HFS
GT2 Cams
B&B
Running max 1 Bar
My setup is:
1994 3.6T
Single plug
K27HFS
GT2 Cams
B&B
Running max 1 Bar
Hi Miles
Quite a transformation that you have undertaken on that beauty!!
I believe "sonny1" has some maps that can help you out, he is a very helpful and knowledgeable guy, try sending him a PM as he does not visit very often the board.
Looking forward to see how your project ends up.
Cheers
Jean
Cheers
Jean
Hey Jean,
thanks! I dont think I have stopped playing with the car since I got it back from Dubai
Thanks for the heads up I will contact Sonny.
Hope all is well... one day I hope to have a ride in the GT2.
Miles
Miles
