MAF Sensor Problem? (longish post)
#33
Jean,
Thanks for the valuable info. I've written to Protomotive and asked to see the dyno pix. I'll keep you posted as soon as I get a reply.
It'll be great to see you on that drag strip... Hopefully the EVO 900 will be there
I'll take it easy on the day just to see what sort of timings I can get.
Khalid,
Great, looking forward to seeing you!
Best regards,
Ziad
Khalid,
Best regards,
Ziad
#34
Jean, I talked to him and he's not going to be attending.
Ziad, is there a motorsport engine mount for your car? If there is, go head and add it to your must have list. I know that on my car it makes some difference in keeping the engine from moving alot on it's stock rubber mounts.
#36
Khalid,
Thanks! I'll drop by the garage...
Jean,
Cheers....
Guys,
Wrote to Protomotive. Jean was right about the HP limitations of the k16s. 430hp is about the limit for the stock turbos. I understand that the Protomotive entry-level upgrade will give a 20-25% increase in torque (over stock), earlier spooling and better throttle response.
I'm now investigating a hybrid upgrade to see what the difference in cost is. My ultimately objective is a RUF Turbo R conversion , so in the interim, I don't plan on spending too much but would like a power hike.. Let's see. I'll keep you all posted.
I know this is off topic, but out of interest, what would kind of Turbo would Porsche need to produce for you to (seriously) consider replacing your beloved 993tt - I'm sure you've all thought about... Do you think I should post this topic seperatly to see what everyone on the forum thinks?
Best regards,
Ziad
Jean,
Cheers....
Guys,
Best regards,
Ziad
#37
Best regards,
Ziad
#38
Ziad, keep the power where it is, at the moment. Upgrade the rest of your car and then add the horsepower. It also gives you a chance to get used to your car on the track, everytime you change something, instead of modding everything at the same time.
