Boost Guage is acting up...reading .2 bar on startup...
this started about a week ago and has been intermittent. it will do one of three things:
1. Start up on .2 bar and stay there, although it will go up to .8 under accel.
2. Start up on .2 bar but go back down to zero on off throttle conditions after a few minutes and then operate normally.
3. Start up and idle at .0 and operate normally.
Temperature and moisture don't seem to have any relationship to its acting up.
Any thoughts/recommendations?
I get this also.
I believe the sensor may measure atmospheric pressure, which could affect the boost gauge depending on conditions?.....check your barometer prior to start up
Is this a possibility or am I talking rubbish?
Have a good weekend all.
Martyn.
Martyn.
mine does this also. i did some search on archive and it is boost sensor. ppl have successfully changed it out. i'll do mine when i get around to do the maf sensor which i'll do when i do my pss9 thats sitting in the garage... haha
