TT-S front scoops - Light? & who has connected brake lines?
Im considering doing the TT-S front air scoops.
2 questions:
1) is it worth it to run the hoses to cool the brakes? or does it just look cool to have the 2 holes in your bumper
2) Do i loose the entire fog light (US bumper w/bumperette), what about the small light that remains with the air scoops
thanks
2 questions:
thanks
") is it worth it to run the hoses to cool the brakes? or does it just look cool to have the 2 holes in your bumper
If you track the car the brake cooling helps, however you'll need to remove the bumper cover and drill holes through one of the panels for the cooling hoses. TechArt has a kit that is far better.
You will loose the fog light as the Turbo S lights are really just like a running light with very little candle power. IMHO not a very useful upgrade.
I got much less pad transfer after I did the complete cooling package with the hoses, so I'm sold on it's effectiveness. I did not have to remove the bumper cover to run the hoses. I thought the fog lights were just as dim as the running lights, but didn't do a side by side compare.
Originally Posted by Rob 97 993c2
john-
which is the better scoop with the brighter light? where to get? did u do this mod?
Originally Posted by Rob 97 993c3
btw, thanks again for all the advice the other day.
