Techart stuff
On my previous GT3 I had fitted Techart Formula GT wheels with these sizes:
front 8,5 x 18h2 rt 151 et 40
rear 10.5x 18h2 rt 152 et 60
tyres pirelli pzero corsa 235/40 zr 18'/ 295/30 zr 18
when the gar gone sold I retained this set which i would like now to possibly put under 993 tt wheels arch. Do you know if operation is doable? Can these wider wheels be accomodated in the 993? Also can these wheels be coupled with 993 tt tyres of standard size?
Thanks a lot for any advice
brgds
SM
brgds
SM
SM,
The original rims on the 993 Turbo has the following dimensions:
Front: 8 x 18 et 52, Rear: 10 x 18 et 40.
You should be able to fit the Techart wheels if you play around with spacers, I don´t like spacers
myself but that´s another story. And the Techart rims in the size you mention can accomodate
the standard tire size of the 993 TT, Front: 225/40 R 18, Rear: 285/30 R 18.
Good luck!
Good luck!
