993 Turbo Forum 1995-1998
Things to look for before you buy
Old Feb 22, 2026 | 01:39 PM
Williewest's Avatar
Williewest
Default Things to look for before you buy
Common Electrical Issues
1️⃣ Engine Wiring Harness Degradation
Problem:
  • Insulation becomes brittle from heat.
  • Cracks cause intermittent misfires, sensor faults, no-start issues.
Fix:
  • Replace the engine harness (don’t patch).
  • Porsche updated harness materials later.
  • Budget: $1,500–$3,000 parts + labor.
💡 If you’re building cars or working on complex systems (like your CNC projects), you know patching old wiring just creates future headaches.
2️⃣ Alarm / Immobilizer Failures
The factory alarm module (M535) and immobilizer are notorious.
Symptoms:
  • Car cranks but won’t start
  • Random lock/unlock issues
  • Battery drain
Fix Options:
  • Rebuild the factory alarm module
  • Replace with a modern immobilizer
  • Have a Porsche specialist reprogram system
Avoid cheap bypass hacks — they hurt resale value.
3️⃣ DME Relay Failure
Classic Porsche issue.
Symptoms:
  • Car dies suddenly
  • No fuel pump activation
Fix:
  • Replace DME relay (always keep a spare in glove box)
  • $40–$80 part
Small part, big headaches.
4️⃣ Ground Strap Corrosion
These cars are 30 years old.
Symptoms:
  • Weird intermittent faults
  • Dash flicker
  • Hard starts
Fix:
  • Clean and replace:
    • Transmission ground strap
    • Battery ground
    • Engine ground points
This alone fixes many “mystery” problems.
5️⃣ HVAC Control Unit Failure
The climate control head unit often fails.
Symptoms:
  • Dead display
  • Blower not working properly
Fix:
  • Send out for rebuild (common service)
  • ~$300–$600 rebuild
6️⃣ Window Regulators & Switches
Age-related wear.
Fix:
  • Replace regulators
  • Clean switches
  • Check door harness flex point (wires break inside rubber boot)
7️⃣ ABS Warning Light Issues
Often due to:
  • Wheel speed sensors
  • Wiring corrosion
  • ABS control module
Scan with proper Porsche diagnostic tool (Durametric or PIWIS).
8️⃣ Battery Drain (Parasitic Draw)
Very common.
How to Diagnose:
  • Multimeter between battery and ground
  • Pull fuses one by one
  • Look for alarm module or radio causing draw
These cars hate low voltage.
Old Feb 22, 2026 | 10:19 PM
pddickwin's Avatar
pddickwin
Thumbs down
Is this low effort copy paste from AI really necessary? Any one of us could have gone to Gemini or ChatGPT and asked this question.
Old Feb 24, 2026 | 04:43 AM
TakeFour's Avatar
TakeFour
Bit harsh
Old Feb 28, 2026 | 12:44 PM
erick993's Avatar
erick993
The engine wiring harness was only an issue on the 1996 turbo not the 1997. There was a recall on the 96 - I have a copy of the recall notice. I have an extra DME relay but never had to use it. These issues above are likely only on very high mile cars that were not maintained and park outside.
Old Feb 28, 2026 | 01:52 PM
Williewest's Avatar
Williewest
Default Adding to your much appreciated info.
[QUOTE=erick993;20472019]The engine wiring harness was only an issue on the 1996 turbo not the 1997. There was a recall on the 96 - I have a copy of the recall notice. I have an extra DME relay but never had to use it. These issues above are likely only on very high mile cars that were not maintained and park outside. 1997 Model Consideration
Official government recall databases (e.g., NHTSA/CAS) may not list a specific recall for 1997 993, but the Porsche campaign still applies to 993 cars whose harnesses pre-dated the upgraded part.
If a 1997 Turbo still has the original harness (older part numbers like early “-00/-01/-04/-05/-06/-07/-08/-80”), it may qualify for inspection/replacement under the same service action because it’s a known deterioration issue.
