993 Turbo Workshop Manual - Where to Find?
If you PM me your email, I can forward you a set of the 993 turbo manuals.
Changing the front diff oil is relatively an easy job. First is to remove the cover to gain access. You'll need a 10 mm allen wrench to loosen the plugs. ALWAYS remove the fill plug first. If you pull the drain plug and for some reason can't get the fill plug out, you're screwed. I would recommend using a 10 mm allen socket because the allen wrench doesn't go in too deep and there is a chance that you'll deform the plug when removing it. In my case, I had to use a breaker bar and a cheater pipe as the plug was difficult to break loose. As usual, YMMV.
JC 96 TT
JC 96 TT
