993 Turbo AC Bracket
Hello everyone,
I own a 1996 Porsche 993 Turbo that was previously converted into a track car. Unfortunately, during the conversion, the bracket supporting the AC compressor was cut. I'm now in the process of reinstalling the AC system and need a new bracket that includes the compressor mount.
It's important to note that this bracket differs from the one found in a base 993 coupe. My independent repair technician has already contacted Porsche in Germany, but we've had no luck so far.
Does anyone have this specific bracket in stock or know where I can find one? Any leads or suggestions would be greatly appreciated.
Thank you in advance for your help!
Solaris
Solaris
Yes, it's the factory bracket. The difference between 964/993 brackets and this one is that the 993 Turbo bracket has a turbo oil pump lodged between the bottom end with 2 oil lines. Turns out LA Dismantlers doesn't have it and I've checked with Suncoast Parts as well with no luck.
Solaris
Solaris
