brake squeal
The little adhesive clips that fit between the caliper pistons and the brake pads usually take care of it with a reasonable level of pad hardness. Often lazy techs will skip them when replacing the pads and you get squealing, or they try to reuse them with some type of glue. Get the new factory parts and they should be quiet.
