993 gt2 g50/54 transmission
what would be the value of the real deal? not too many people know what this is. There's 1 available that maybe for sale.
Value will be decided by market any "guess" here is just that, how bad does one want the authentic item (as seen on FB), as can do as good / better with new gear sets, so performance price is determined by like non OEM new - for pure performance sake, but for a collector / historic build, BAT says crazy money is out there. Then there is bespoke Linton trans project that will be unobtainium.
kabsncoupe (02-09-2022)
I recently was able to acquire a G50/31 Cup trans fresh spare from a customer campaigned 993 RS Cup and the price was mid $20 k , I was fortunate enough to obtain factory aluminum hood and Cup tail in the deal so I would venture a used GT2 993 trans to be at least in that range ,$25K plus ...
Bert
Bert
Bert
Bert
How do the ratios of the G50/54 differ from the G64/51?
RSR used either g50/30 or g50/34
street base RS used g50/31
street RS/CS used g50/32
all of the above have the same external dimensions and mounting points
993 turbo and GT2 all use a trans w/ larger exterior dimensions which move the output end mounts, reason is the larger CWP used on these transmissions
gearing on these is much taller than the n/a aspirated g50s
Thanks Bill. Your graphs and sheets are always fun to dig into.
Sort of a side stepped question, but has anyone here heard of people replacing 993TT gears with 996 gears/ratios? For the most part (1-4) they appear to be the same, but I came across a car that has GT3 gears for some reason.
