Front area thud in stop/go traffic
Do any of you have a mild "thud" when starting from a dead stop in stop/go traffic. It feels almost like an anti-roll bar is binding and releasing when the nose lifts. I haven't taken it in to check what it is, but wanted to see if anyone has had this before?
I checked the archives and found one person that had, but there was no resolution given.
Thanks!
Thanks!
Jeff, I will check, but it sounds mechanical rather than something moving around. Feels like something binding, then releasing when enough torque is applied. Hope it's not the front diff or driveshafts!
Check the coilovers and make sure the bolts are securely fastened to the car's shock tower under the hood.
I have heard that noise before when the spring that is mounted on the coilover isn't seated properly and moves around. Remove your front wheels and visually inspect the spring to make sure it is seated properly.
Just a thought...
Just a thought...
Originally posted by ZCAT3
That does sound like coil-over spring clunk, which you should not have in a 993. Does in tend to happen when you first get under way and turn a corner (such as leaving the driveway)?
I have it scheduled to go in next week so we'll see if something is loose or binding. I'll report back.
