Any 993 turbo workshop manual owners that can share 2 sheets of your wiring diagram in colour? I have the cheap PDF workshop manual and the wiring diagram the prints are very hard to read.
I need sheet 911 Turbo (993) model 96 engine electrics M2.10. fuel, ignition system, cruise control sheet 5A and 5B either in picture or PDF files if you have a scanner big enough.
Your help would be greatly appreciated.
You can email the colour pictures of the diagrams at torokanthony@gmail.com or via text message at +1 (514) 662-8116 which I think would be easier if you take the pictures with a cell phone.
A quick why the difference "scan", the 2nd "set" on the A drawing has a number of additional components around the edge. (A41, H41, A50, E50). Those elements should guide as to which set you need.
This missing elements in the 1st set on the A drawings are also missing in the 97/98 set it appears.
Bentley 993 Book has all wiring diagrams as an appendix (TT like Cab is just an option code in the diagrams) you can buy.
There are also PDF copies (of various scan quality floating around - search rennlist and google for PDF download links - the links can go stale after a few years) or workshop manuals (Pelican, ECS, eBay, etc.) from the factory with wiring diagrams too that can be purchased (new or used).
Although all the sheets say '911 Turbo (993).....' at the top, there's only the last diagram that is actually for the turbo because the rest are for twin plug motors. There may be turbo-relevant info on the first three but the DME info itself is definitely different between the two.
I would really appreciate it if someone could do a good scan or photo of that last sheet 'Model 96 SHEET 5B' please. The resolution on these images isn't quite good enough to see what the DME pin numbers are.
If you a referring to the square boxes (numbered in side the box boarder) show along the wire path in the drawings, I do not think those are junction boxes as such, but are just inline "splits" in the cable bundle were a wire is pigtailed/split into 2 or more additional wires going off in multiple paths to different terminals/pins with the same voltage/signal.
