Brake cooling ducts for AWD 4WD C4S Turbo
Wordsmith
This is a long-standing issue with Turbo and AWD cars, but I want to raise it again --- as anyone cracked this nut?
I received an email from Andial saying they have something (for $1000) but no pictures -- just send the money. Not impressed.
My next step is frozen rotors and some half-arsed ducting and deflectors. I have pictures of the system on the '04 GT3RS -- I'll be trying something similar. Probably in fibreglass ... grumble...
I've got the S ducts connected to hose ducted into a deflector that continues above the existing deflector on the lower control arm. I don't know if Performance Products still has them, but it's pretty effective and doesn't interfere with steering.
Wordsmith
If someone could run with their brake ducts blocked and pyro the rotors and calipers then run with the ducts open and compare the temps, maybe that's enough to know if the cooling is working -- thinking in terms of "I feel fade" or "spongy pedal" seems too subjective.
Once my front wheel wells are fully booked with rubber, I expect I'll have to duct the air from further back in the fender (at the centre of the wheel and scooping air from below the body.)
Performance does have things and I'll likely use their stuff to save the raw fab work, but it will need a lot of fiddling to work around front drive shafts and really force the air into the centre of the rotors.
A lateral thinking approach would be to just lighten the car by 1000lbs...
ps. Thanks to everyone that resisted shoving a "search the forum" post on this thread
