993 Turbo Forum 1995-1998
GT2 Power Kit
Old 08-14-2018, 04:18 PM
mowaffaq
mowaffaq's Avatar
Default GT2 Power Kit
Good day folks,
First post on 993 turbo forum
I was reading about a Porsche dealers' installed "GT2 Power Kit" for 993 turbos.. and nowhere was I able to find what this entails. Many threads talked about different levels of horsepower at different levels and one addressed a Power Kit that involves chassis and transmission mods.
I called two Porsche centres and I'm still awaiting their formal responses.
Any insight into this would be greatly appreciated!
Old 08-14-2018, 10:53 PM
racer959
racer959's Avatar
Never heard of it.
Old 08-16-2018, 01:01 AM
DiegoR
DiegoR's Avatar
Maybe they refer to GT2 or RoW Turbo S retrofit kit offered by porsche (DME and K24 turbos)?
Old 08-16-2018, 08:00 PM
TurboIXXI
TurboIXXI's Avatar
X50?
Old 08-16-2018, 11:40 PM
mowaffaq
mowaffaq's Avatar
I wish I knew! But I think it is the turbo S set up with K24 turbos as Diego said. I’m going to the shop tomorrow to take pictures..
will report back!
Cheers
Old 08-17-2018, 08:21 PM
TurboIXXI
TurboIXXI's Avatar
RUF Turbo R conversions?
will report back!
Cheers
RUF
Old 08-17-2018, 09:47 PM
mowaffaq
mowaffaq's Avatar
Alright Gents,
The kit includes DME, K24’s, intercooler and exhause tips. Yes, just the tips!!
C$18,500 plus labour; 2011 prices
Thanks to those who chimed in.
RUF
Old 08-17-2018, 09:51 PM
Basal Skull
Basal Skull's Avatar
What intercooler would that be?
Old 08-17-2018, 10:01 PM
mowaffaq
mowaffaq's Avatar
Good point!
it’s a Porsche intercooler that to my “untrained eye” looks stock turbo. The foreman could not ascertain whether an extra oil cooler is part of the kit since the car in question has it but the factory description did not.
Old 08-18-2018, 02:14 AM
Basal Skull
Afaik all the ‘gt2’s’ used the standard intercooler except the gt2 evo which uses a scan with a 180 degree/na type intake and doesn’t fit under a stock lid. The only real ‘upgraded’ intercooler that actually is a true upgrade and more efficient (that also looks stock) is he Andial intercooler which uses stock end tanks/center section with thicker bar & plate cores. It uses the stock shroud but the shroud is modified (loses the ‘lip’ around the opening) and fits under the stock lid. If you can get a pic, we can identify it. 18k ?cad, In 2011 that’s pricey even with an intercooler.
Old 08-18-2018, 08:36 PM
DiegoR
DiegoR's Avatar
X50?
My 97' turbo came with wide oval tips and bunch of options including X79, also the X50 which bump the power from 408cv to 430cv with the small K16 turbos. My car was "upgraded" when was new by the first owner when dealer purchased the Porsche "Turbo S" retrofit kit. That TSB is posted in this forum and list all the components used to make the retrofit and for different markets, including the aux. front oil cooler, which mine came factory optioned already. The exhaust is only the "double" tips changed, not the "cans" (mine was changed in the upgrade when was new as well). My DME is a RoW Turbo S (and I guess GT2 as well) paired witht he K24 turbos as per offered by Porsche as upgrade. I found later that they missed installing two 02 sensors (my car doesn't have check engine light option/symbol and didn't bring 02 sensors) but had to be retrofited when using this upgrade according to the TSB.
Let me know if you need any other info that I might know and glad to share. Though, there's many members that way more knoweldge than me to share experience.
Old 08-19-2018, 09:07 PM
mowaffaq
mowaffaq's Avatar
Here you go
Old 08-19-2018, 10:54 PM
Basal Skull
That’s a bone stock intercooler..
Old 08-22-2018, 08:58 PM
ToSi
ToSi's Avatar
factory docs posted by geolab years ago
Looks like there were 2, this kit took the engine from 400 -> 450hp and included turbos, oil cooler & a new DME:
and this one meant for 430hp versions that already had the oil cooler, only turbos + DME:
Old 08-22-2018, 10:02 PM
mowaffaq
mowaffaq's Avatar
Excellent work! Thank you for the uploads.
How do you folks think this upgrade would reflect on values expecially in the current market?!
Quick Reply: GT2 Power Kit
