sunroof upholstery failure
Anyone else experience the leading edges of their sunroofs' upholstery coming loose from apparant glue failure? Could this be an indicator that the sunroof has been worked on in the past, or is this just a normal wear and tear issue?
Thank Lance
ps it's too cold for using sunroof in Eastern Washington right now anyway.
Thank Lance
Thanks Old Guy,
I had no records of previous repair but am ever-paranoid of past undisclosed history of car since I bought it last December.
Thanks Lance
Thanks Lance
Mine came loose on my 96 and I repaired it using some contact cement its pretty easy just be careful with the contact cement as it can be stringy and once you put the 2 pieces together there stuck there. Doug
