993 Forum 1995-1998
95 993 engine
Old Nov 20, 2003 | 08:18 PM
sleder's Avatar
sleder
Default 95 993 engine
I would like to find out more info about a '95 993 engine...where do you suggest? Things like weight, HP, torque, typical issues, redline, powerband...
I can use all the help I can get. Thanks in advance
sleder@ix.netcom.com
Old Nov 20, 2003 | 08:23 PM
graham_mitchell's Avatar
graham_mitchell
Here's a start...
Engine: 6-cylinder boxer engine (air-cooled)
Compression ratio: 11.3:1
Displacement: 3600 cm³
Output (kW/bhp): 200/272 at 6.100 rpm
Torque (Nm): 330 at 5.000 rpm
Taken from Porsche web page: http://40jahre.porsche.de/en/common/...ng=2&gen=3&n=3
Old Nov 20, 2003 | 08:31 PM
sleder's Avatar
sleder
Thanks...I appreciate the site info as well.
Old Nov 20, 2003 | 11:48 PM
Bill Verburg's Avatar
Bill Verburg
  • M64/05
  • bore 100mm/3.94in
  • stroke 76.4mm/3.01in
  • disp 3600cc/219.7ci
  • cr 11.3
  • power EC 80/1269 200kw/272hp @6100
  • torque 80/1269 330Nm/33.6kpm @5000
  • max speed 6700 +/- 20
  • weight 232kg/510.4 (fulley dressed as installed w/ all accessories)
No major issues, a few minor issues associated w/ track use like rod bolts
Old Nov 21, 2003 | 08:48 AM
sleder's Avatar
sleder
About what point does the rod bolt issue becoe evident? Approximate mileage?
