993 RS clutch + LWF kit installation problem
Hi guys,
I've got a quick question.
As I mentioned above, I just replace the RS clutch and LWF for my 993.
I could start up the engine.
But the problem is release bearing fork seems to be little bit short.
Which mean, I can't put the gear in.
Does anyone have this problem?
I don't know If I need longer fork or not.
I though I got the complete kit from carnewal, so I don't think I need further parts for this work.
little bit confused here.
Any comments will help me a lot.
Thanks guys
Lim
Thanks guys
Lim
Hi guys,
Thanks guys
Lim
Thanks guys
Lim
944.116.080.01 release bearing
950.116.813.30 guide tube, I believe this is the short one but would need to look it up to be sure
AFAIK, the throw out bearing for the super cup clutch is different as well. You might want to compare the bom of what's included to what others have installed. I have a picture of all the needed parts posted here somewhere. Sorry if I can't get you the link right away.
Ed
Ed
Thanks Bill!
Thanks Ed!!
Actually it was simple mistake.
I put the clutch disk in the other way.
I had to take my transmission out to check, but I got the problem solved.
Thanks guys and also thanks to Gert from Carnewal.
HS Lim
Thanks Ed!!
HS Lim
