2 Post Lift - Engine Drop - Lift Table
I'm preparing for my first engine/transaxle drop from my 993. I have a two post lift. From what I've read and searching, a lift table may be beneficial to the process. (i.e. lowering the engine out vs raising the body up with the 2 post lift.).
Does anyone have any recommendations on a lift table? So far I'm looking at this one. http://www.gregsmithequipment.com/1-100-lb-Table-Truck
Thanks,
Mike
Thanks,
Mike
I used one from Harbor Freight for my engine swap. It's definitely not the greatest quality, but I figured it only had to go up and down a couple of times. ![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Why not just use the 2-post lift and a sturdy box or table?
I'm worried about the sensitivity of the lift up and down causing issues. The lift table should enable more 'precision' to the positioning of the motor/trans during install.
The Greg Smith Equipment companies "Table Truck" offer at $455.00 could work easily,, having a working capacity of 1,100 lbs.
The above ^ wooden shop bench construct has appeal because of its DIY value and shape; its rectangular shape easily accommodates the 993's gearbox/engine arrangement combo.
The recently installed 2 post lift we have both raises and lowers effortlessly ... that is without shudder.
