Tramont Cup wheels for the track?
Hi everyone,
I'm posting here even though I have a 997 because I need some feedback regarding the Tramont Cup wheels. Since I'm the only one that has those on a 997, I need some help from my fellow 993 rennlisters.
Is it ok to use these wheels on the track? I'm planning to do four 20 minute sessions next week and I haven't tracked the car since I got these wheels a few months back.
Thanks!
Below a pic of the wheels I'm referring to:
Thanks!
Just wondering if anyone had experienced any cracking or similar issues. I know Tramont makes a quality product, but when it comes to the stress levels experienced at the track wanted to double check if there where any negative experiences.
My guess is that it should be ok, but I'm just doing my homework. It doesn't hurt to ask
Hi everyone,
Thanks!
Thanks!
https://rennlist.com/forums/993-foru...track-car.html
Your car looks sweet!
Why wouldn't they be fine? You're probably putting less stress on them at your first track day than driving across a bunch of potholed highways on the way there. The big thing to check is the condition of your lug nuts/studs/bolts, and if you're using spacers, be sure you've got enough threads engaged.
This feels like more of an excuse to show us your purty retro 997.
I believe Paddy does and gets great times --
This feels like more of an excuse to show us your purty retro 997.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
The reason why I'm asking is a combination of these being the first non-oem wheels I've ever put on a car, and the typical Rennlist paranoia of reading so many stories about cracked non-oem wheels at the track.
I installed titanium bolts when I got the wheels, the front ones being extended to account for the 5mm spacers that I had to install due to front caliper clearance issues.
On the track the wheels endure longer and more extreme heat cycles, far more than anything on the road. The spokes and the outer rim undergo prolonged tension during cornering (more than you think).
A pothole on the other hand is a brief and very focused point of stress. Depending on the hole, speed, wheel, car, etc., a hole can break any wheel.
Pothole damage is typically immediately apparent - a bend, crack (have to check for them), or totally destroyed wheel.
At the track, bad wheels can develop cracks around the bolt holes, spokes, or really anywhere if the quality is bad enough.
I'm not here to say whether Tramonts are good or not - I don't know. But it is worthwhile to invest in good wheels for the track, and regularly check them for defects.
And they look very nice on your 997! Especially with the stripe.
Maybe. But unless you're going very, very gingerly, track driving creates a lot of stress.
+1
+1
The actual driving, no I wouldn't worry about that. but if you do what most do, you'll swap the tires for
R-rated tires, they stick better and take the heat better, but wear faster. This means more frequent tire
swaps, and this is when wheels get cosmetic damage.
Also the outer barrel on Tramont Cups are anodized, hence repairs are more difficult than you would have on painted wheels.
