I'm looking for an old 993 engine wire harness in order to use a couple of the connectors for a project. If you replaced your failed original and still have it, please let me know.
More specifically, I need the connectors (plus wire leads) that attach to this style of socket. The harness that goes to the fan belt sensor ends in the correct connector:
Andreas , I'm out of town till Friday but I have a roached 993 harness I can easily pull that connector from and send to you if that's what you need .
Pm your address and I'll put it in the mail, Bert
Google 'EV1 injector connector', that's a standard part & readily available.
Thank you for the heads up - will investigate.
Bert,
That's very kind. If I could have you check the connectors first to see if one has the correct pattern, we can go from there.
