sealant for rear reflector?
I recently purchased a new rear center reflector to replace my hazed-over original unit. The new one looked great, but after the first washing it was apparent that the new part was not water-tight like my old one. It wicked up lots of water into the reflector housing which later turned into condensation.
Upon closer inspection, you can clearly see that the black rubbery sealant used to join the red reflector lens to the black plastic housing was mating both surfaces together in the corners and edges, but it did NOT mate the long edges. The bead of sealant was run a couple of mm too far in from the perimeter edge to actually contact the reflector edge.
My local dealer re-ordered 3 others, and they all had similar issues - but to varying degrees.
So I'm going to fix it myself. Does anyone know what type of sealant is best used here?
Seems to me you will want to use a sealant that does not attack the plastic. I would consider clear 100 percent silicone bath caulk. It can be gotten in smaller squeeze tubes for precision application. Just remember less is better with these sort of sealants. I am not really sure how well the housing is sealed in the first place so I would leave some open sections so it can drain any liquid moisture that might form inside.
Andy
Andy
I used this for my fog light restoration and it really does dry super clear. Also remains flexible & stretchy. Good stuff. Ace Hdw here has it in small tubes.
http://www.sashco.com/products/lexel/
My last new reflector had lots of air gaps, and if circulation or drainage was important the condensation would have eventually dried. But after weeks of dry conditions and heat from the sun and from driving, there was no sign that the gaps promoted any drainage or drying.
I was intending on using a similar flexible black caulk/sealant as what is used from the factory, but might consider clear silicone if I can't identify it here.
Any ideas about how to ID the factory caulk?
^NP. Only caution I'd add is that it's extremely sticky out of the tube and and hard to clean up if you happen to smear it. I'd recommend fully masking everything but the gap.
Just return it, and see if you can get another one, Porsche parts come with a 1 year warranty. I had the same experience as you a year or so ago, I replaced my center reflector and the new one filled with water when I washed my car. I brought it back to Porsche and they ordered a new one and that one ended up leaking too! However, the third one we ordered was perfect and did not leak.
I ordered and returned 3 units, and each was as poorly sealed as the others. The parts counter guy and I felt like we'd be playing the order/return game indefinitely, and there is apparently no way of communicating with the parts factory about it. So I've decided to try to solve the problem myself...
Technical Guru
Sent you a pm. Can you post some pics of this issue and where the sealing needs to be redone? I replaced my reflector too this winter but car is in storage. I wonder if I have the same issue to address before I wash the car. Thanks in advance!!
Buy some of this http://www.ebay.com/itm/Windscreen-S...pYQ9Ir&vxp=mtr
It's all you need plus a surgical scalpel blade to cut it into thinner strips and press it into the gap with a tea small spoon.
A quick and easy fix
