Is my 993 C4S overheating?
#46
Do the easy things first. Assure plugs wires are correctly positioned. Use a continuity tester to make it easier. Eliminate one item at a time, keeping track what was changed, replaced, moved.... Let us know what ya found. Where'd the engine come from?
#47
What's the issue? Assuming it was quality synthetic, 0w40 is Porsche-approved according to these TSBs:
http://www.pcarworkshop.com/images/1...03usgeolab.pdf
https://www.porscheclubgb.com/PCGB/m...0.pdf?ext=.pdf
20W50, however, is nowhere to be found on the lists...
#48
#49
Originally Posted by vincer77
Probably because Porsche recommended it.
Not that they were right, but he has seen the error of his way and corrected it.
You should applaud him.
Since I live in Texas and the 100 degrees summers, the heavier weight made sense on an air cooled engine.
I will say ...the mobil v-twin works amazingly well...in my car :-)
#51
Good Turn Out
I just got it back this week from the shop.. In a series of fortunate events it turned out to be that the reason there was low oil pressure was a oil release piston was not put back in when the engine was being tinkered with/ swapped. Also the misfires where from one of the main sliders for the ignition system being loose.. All is well with this car now Thank you all for your input
#53
I would at least have valve covers removed to inspect cams and rockers for evidence of oil starvation.
