Porsche PET Parts Software + Windows 10?
The Ebay CD is the pdf format that you can download for free from Porsche.com. $152 is a complete ripoff! That cd used to be about $10 from a dealer.
I use Partslink24;
https://www.partslink24.com
I cant help on anything regarding a disc though!
I use Partslink24;
After a day and a half, mostly spent staring at the computer until droplets of blood formed on my forehead, I got PET installed and running. And NO, it won't run on Windows 10. You have to install a virtual machine (I used oracle vm virtualbox, which the techies say is "easy"), then install an older version of Windows (I used Vista because I had the disk handy), then install PET. I feel like I just did something important, but I heard someone mumbling in the background about "yard work" or some such trivia.
7.3/405
7.3/405
It is possible to install PET direct on all variants of Windows 7, 8, and 10, x86 and x64 versions without a VM, but it does require a bit of acrobatics. The advantage is it starts up and data loads immediately.
Cruisin'
PET2 or 7 sources & install ? (esp Win-10)
i have PET6 on an XP which am about to junk as i convert to Win-10 - dunno how i got PET6 or how it was installed since i don't seem to have a CD for it
(i also have a Win-7 PC it could be put onto, which will remain alive for a few yrs more)
found this PET2 offer
http://www.autopodaci.com/itemPages/...ORSCHE_PET.php
(seems to be a bit convoluted ordering process)
and find several PET3 download offers like this http://blog.uobdii.com/free-download...talog-2016-04/
and http://www.uobdii.com/wholesale/spar...-cars-pet.html
- mostly from non-usa sites in places known for hacking - so am suspicious if they contain malware
has anyone bo't &/or installed any of these?
p.s. - don't need the newer cars stuff in ver 7 & 2, but would happy just to be able to run on a new PC
Widows ten has an option to load programs in a mode that looks like previous versions of Windows to older applications called "compatibility mode". I suspect if you use this feature it will run. I have found Windows 10 is capable of running very old software and works with very old hardware cards with a little work at install on configuration.
Andy
Andy
Cruisin'
update
as an experiment - i just copied the 2 PET folders from my XP C: root (32bit) over to my Win-7 PC C: root directory (64bit)
- it works perfectly
folders are PET_PROG & PET_ROOT - the PET.exe launch is in the _PROG folder - just send a shortcut to desktop
then - i found my original PET6 zip file on one of my other drives -
only thing left is to test it on the new Win-10 setup - i'll update when i have an answer to that
p.s. - the 2 folders = about 185 MB disc space
Technical Guru
Here's a link to the PET manual. It's free and direct from Porsche.
https://www.porsche.com/usa/accessor...artscatalogue/
After the link opens, scroll down and enter the model you're looking for. It's online so you always have it available, and did I mention it's free?
