Getting my fan and shroud refurbished and need help identifying color
02-22-2017, 09:30 PM
Quote:
Cerakote is absolutely compatible with magnesium with no change in temperature stability.
Absolutely, this was a concern I had but was told it's fine.
02-23-2017, 05:55 PM
Quote:
Originally Posted by
P-daddy
A local Shadetree Speedshop recommended this color for my last shroud paint job. It turned out terrific!
How did you prep it before painting? I have a lot of chalky deposit on the interior of the shroud.
11-02-2018, 12:58 PM
7th Gear
Satin Mag is the cerakote color.
11-05-2018, 10:52 AM
I'd like to do this as well. Do the shroud and fan come off easily?
11-05-2018, 07:27 PM
Endoman
Oops... pardon the delay. Bead blast
Jay777
If you’re handy with tools, not bad at all. The only special tool you’ll need is a 3-prong puller to extract the fan from the fan bearing/alt shaft.
