Oil Pressure Gauge
Oil Pressure Gauge
Can some one give me a 101 on the oil pressure gauge in these air cooled 911s.
Where should the needle reside when cold, hot, where on the indicator should i be concerned? To be honest i always focused on the oil temp and never really understood the gauge well enough to use it as a tool to read how my car is performing.
My pressure gauge is pegged at 5 bars for practically anything except for idling.
At idle, it shows about 3 bars, give or take a little depending on temperature.
I suspect that if anything catastrophic happens that causes a significant loss of pressure, the damage will probably already be done before you notice the gauge.
That is exactly how mine behaves
I did not see any movement from when i started it today and after 45 minutes of driving
I would have thought as the engine oil heats up the pressure would drop
Cold, it should be at 5 bar. Warmed up at idle, it should be between 2 & 3. Then while driving, any thing over 2000rpm, it should back around 5.
At idle:
It works a lot like the oil level gauge that indicates oil level when hot and relative temperature/viscosity of oil.
- Cold 5 bar
- Warm 2-3 bar, this is when you can measure your oil level with the dip stick.
- Very hot, after say an auto cross run in hot weather just at 2 or slightly below.
