993 Forum 1995-1998
A-arm removal?
Old Jan 13, 2017 | 04:14 AM
  #31
bcameron59's Avatar
bcameron59
Originally Posted by red67vert
OK, I'll look for the tie rod threads. When I started this thread I was just doing A-arms.
Now you guys have me talked in to doing all three. But appreciate the advice. I really would like toget rid of that little squirliness. Thank you! Thank you! Thank you!
Heh heh. Another one started on the slippery slope.
Our work here is done.
Old Jan 14, 2017 | 08:10 PM
  #32
Tlaloc75's Avatar
Tlaloc75
I got my car up on jacks today and observed the bushings while jacking up the front suspension. On the trailing bushing I noticed that the bushing inner shell moved, the outer shell stayed in place and the bushing itself appears to have a torquing motion on it. This leads me to believe that it is in fact necessary to load the suspension before tightening.
I agree that ramps are the best option.
Any experts want to weigh in?
Old Jan 15, 2017 | 12:13 AM
  #33
red67vert's Avatar
red67vert
So are you saying, assemble everything finger-tight put car back on the ground, then drive it up on ramps or lift, then tighten to specs?
Old Jan 15, 2017 | 12:24 AM
  #34
Tlaloc75's Avatar
Tlaloc75
You can probably go a bit more than finger tight, but I wouldn't go full torque till it's loaded. You can loosen, to ensure bushings orient properly, and re tighten to full torque once its on a ramp.
I'd also recommend jacking the rear up so the normal weight distribution is in place. If only the front is on ramps, the suspension won't be fully loaded.
Old Jan 17, 2017 | 03:32 AM
  #35
bcameron59's Avatar
bcameron59
Came across an earlier thread on this topic, basically if you have oem style bonded rubber bushings, you should preload before torquing, but if you are doing polyurethane bushings it doesn't matter because they can rotate freely as they are not bonded.
https://rennlist.com/forums/993-foru...arm-bolts.html
Old Jan 20, 2017 | 04:07 PM
  #36
red67vert's Avatar
red67vert
Arms, ball joints, tie rods came out without a problem. Waiting for parts to come back, hope install goes as smoothly! Thanks for the education, probably would not have tried it, without your input.
Old Jan 20, 2017 | 04:54 PM
  #37
squidge's Avatar
squidge
