FD Motorsports short shifter versus Rothsport short shifter
#31
Thanks for the input, guys! I'm probably just going to go with the Golden Rod and FDM short shifter. Will check with Darin to be sure, but the Rothsport short shifter with the stock shift **** sounds like far too much money for zero gain.
Fred, thanks! The FD shifter is made for RWD, too.
Rothsport v. FD ssk.
Ditto the above comments.
Rothsport's kit is for 2-wheel drive, not 4. FD's is for 4-wheel drive, which is my car, and what Rothsport installed. I just got clarification from Earle, parts manager at Rothsport.
To repeat, while the ssk doesn't make things too much shorter, only about an inch, its presence along with the GR crisps things nicely.
I notice no increased vibration, noise, or notchiness.
Fred, Portland, OR
Fred, Portland, OR
#32
Mark,
I have the same setup GR & FDM SS. You'll be really happy with it I'm sure.
Plus Darin is a pleasure to work with. Great customer service!
#35
I installed the RS shifter in a C4S. I did not install the longer RS fork based on advice I received at the time. Can someone clear up that for me? Does the C4S not need the longer fork?
I got a longer RS fork and RS shift rod waiting to go in. After seeing Bill's post about the longer RS shifter I need to check that too. Would love to have it a bit taller.
So far no major wow factor. That may change after replacing above parts.
#36
#40
#41
This is a timely thread for me as I'm about to make the same purchase decision. However I want to get away from the stock 'mushroom' shifter which I dislike for its ergonomics and reach. I have a spare stock shifter boot which I can modify to accept the Rothsport shift lever.
In addition for those that have DIY'ed the modification themselves, how straightforward was the installation of the SS kit (including the GR mod) for someone with basic tools and jack stands?
While installing the GR, I would always recommend replacing the nylon cups in the forward shift linkage.
#42
I went with the rothsport rod with function first ****, forward rod and golden rod from fd. It's definitely an improvement from stock but I'm not fully satisfied. Not close to the precision and short action of miatas. Occasionally, I have issues shifting to third under load. In low rpms, all is good. By the way, I also have wevo black motor mounts and ff yellow transmission mounts installed. Not sure if there is any fine tuning possible but from by understanding, its plug and play. My mechanic installed it.
