steve wong chip and idle
i just installed the steve wong chip with the lightweight flywheel option and ron 98
just a question for the people who have the lightweight flywheel option do you guys have the idle high? maybe 1300rpm?
whats is the idle in your car with steve wong chip?
Seared
Steve's LWF chip raises the idle speed, but not that high. Have you driven the car or is that the idle immediately after installing the chip?
Andreas
Andreas
hope i can get the idle to 950
this is the idle
Seared
From another thread regarding the installation of a Steve Wong chip:
Andreas
1. Turn key to on (but not start engine) for 3 minutes
2. Turn engine and let idle for 3 minutes
3. Perform 3 cold starts.
4. End
4. End
Andreas
Interesting.
FWIW, I bought the recent version of the Wong chip for my 964 about 6 months ago. It also has RS clutch/LWF setup. However the idle didn't change from stock. I questioned Steve as I thought idle should have been higher. Steve said the newer chip is remapped not to stall yet idle will remain unchanged. So far, the car has performed flawlessly!
Thanks man seems this worked rpms got to normal will try it for a some more time to see if there is any changes.
