993 Forum 1995-1998
Stuck speedometer
Old Apr 12, 2002 | 03:18 PM
aston's Avatar
aston
4th Gear
Post Stuck speedometer
My speedometer gets stuck on zero until I get rolling about 20 -25 miles per hour. Then it unsticks, and it works just fine. This only happens when the car has not been driven for a few days. Is there a quick and easy fix for this I can do myself?
Aston.
Old Apr 12, 2002 | 03:27 PM
Edward's Avatar
Edward
Addicted Specialist
Post
Aston,
I can't speak for the porsche, but this has happened to me in the past in a non P-car. It's the guts of the speedo...not much you can do but live with it or get it fixed. I've had work done on both a tach and speedo at "North Hollywood Speeometer." They've been around for a long time and they do great work. I seem to recall "PaloAlto Speedo" as well in Pano, though I don't know anything about them. hope this helps.
Edward
Old Apr 12, 2002 | 03:53 PM
tom_993's Avatar
tom_993
Post
I could also be the speedo cable. In one of my previous cars, the speedo would stick at any random speed for a while, then unstick and jump to whatever new speed I was driving at. I was able to disconnect the cable from the back of the speedo, and shoot some lube down it. Gravity carried the lube down the length of the cable. I think I used a Teflon type spray. I think there are specific lubes for speedo cables. This lube solved the problem.
Old Apr 12, 2002 | 04:46 PM
Robin 993DX's Avatar
Robin 993DX
Lifetime Member
Post
To my understanding the 993's speedometer is a electrical based system. (Not mechanical cable driven)
The DME get's the pulse signal from the rear left wheel speed sonsor which provides the data in conjunction with the ABS system.
Most likily your problem is associated with the speedometer needle itself.
I would "borrow" someone else's speedometer for testing purpose and determine if that's the culpit.
(Obviously I don't think it is the speed sensors that's causing the problem, or else you would be posting an ABS question instead.)
Old Apr 12, 2002 | 05:07 PM
C4S's Avatar
C4S
Post
Does anyone have the wiring diagram for the speedo plug on a 96 993? That is, the plug that connects to the back of the speedo. I am trying to find out what each wire does based on its color association. Anyone have any idea of what the various color wires do? Thanks.
Old Apr 12, 2002 | 05:09 PM
tom_993's Avatar
tom_993
Post
Really? I could have sworn I saw a speedo cable connecting to my tranny one time when I was down under there for one reason or another. My mistake!
Old Apr 12, 2002 | 05:37 PM
Robin 993DX
Lifetime Member
Post
[quote]Originally posted by C4S:
<strong>Does anyone have the wiring diagram for the speedo plug on a 96 993? That is, the plug that connects to the back of the speedo. I am trying to find out what each wire does based on its color association. Anyone have any idea of what the various color wires do? Thanks.</strong><hr></blockquote>
Can't explain it, I tried.... Had to erase the whole post because it didn't make sense. You really have to look at the schematic in order to under stand it. Unfortunately you need the complete schematics, because it will take you through different pages.
Old Apr 13, 2002 | 01:56 AM
Charles Morrison's Avatar
Charles Morrison
Post
I had this identical problem about nine months ago.
Apparently, the lubricants inside of the speedometer can break down and cause the needle to "stick". Having the speedometer head removed and internally cleaned and re-lubricated (cost approximately $45) solved the problem.
As mentioned earlier, the speedometer (96 993) is electrical and can be easily removed (four wire connectors) from the instrument panel. There is no mechanical cable.
Hope this helps,
Charles Morrison
Old Apr 27, 2002 | 05:23 AM
andypardoe's Avatar
andypardoe
Post
andypardoe's Avatar
andypardoe
Post
Did you ever find out this information - I'm looking for the same.
Old Apr 29, 2002 | 11:05 AM
C4S's Avatar
C4S
Red face
Andy-
I still am looking for it. If you get a hold of it, please either post it or send an email; I will do the same. Robin have you gotten any further on this? Thanks.
E
eisban@yahoo.com
Old Jun 17, 2002 | 11:16 AM
C4S's Avatar
C4S
Talking
I figured out the wiring for the back of the speedometer on a 993. Should you need the info, please email me and I will send it to you. I don't have pics, just what each wire does based on its color association. Thanks. <img src="graemlins/beerchug.gif" border="0" alt="[cheers]" />
E
eisban@yahoo.com
