993 Forum 1995-1998
Diamond in the rough - Pricing?
Old Sep 25, 2016 | 12:00 PM
golfnutintib's Avatar
golfnutintib
to get a 993 'right' for powertrain and suspension, i spent $30k
to get it right cosmetically from decent/used condition i spent another $15k
i am ocd, right means right, i don't wrench
also considering getting a charming 964 right... budget is $35k, and the engine is plenty good
but getting these great old cars right is not for the light of wallet or faint of heart... eyes need to be wide open entering such ventures
Old Sep 25, 2016 | 09:08 PM
Gbos1's Avatar
Gbos1
Originally Posted by stop
How come this vehicle is being compared to a narrow bodied car when is wb?
Just curious if nb vs. wb values matter less in this type of condition?
Being that it's a Tiptronic it might as well be a NB Car......
Old Sep 26, 2016 | 11:18 AM
stop's Avatar
stop
6th Gear
Fair enough
Old Sep 26, 2016 | 04:16 PM
pp000830's Avatar
pp000830
If the leather seats look tired the car has closer to at least 80K miles. Inside the odometer a gear chips and jambs the mechanism. A replacement gear set and a little time on the kitchen table is all that is needed to fix that.
If it is an 80k example
it will need a clutch some time soon
May need 1st & 2nd gear synchros if the shifting feels notchy
If it has the original struts, they are probably in need of replacement. If they have been replaced once, just look under the car you may be good to go for a while.
I wouldn't shy away from this car if you are willing to do some of the work yourself DIY.
Here is my master list of stuff you may run into owning a car with 80K+ miles and needing some work:
File Type: pdf
Old Sep 26, 2016 | 08:05 PM
Disraeli's Avatar
Disraeli
Thank you so much for this! Incredibly helpful information.
Old Sep 26, 2016 | 10:11 PM
Pichu's Avatar
Pichu
I would buy the WB if it was at a good discount. Doing the work is half the fun!
Old Sep 26, 2016 | 11:24 PM
pirahna's Avatar
pirahna
Since when do tiptronics need clutches?
Old Sep 27, 2016 | 10:53 AM
stop's Avatar
stop
6th Gear
Maybe he means for the g50 swap the car needs ��
Old Sep 27, 2016 | 11:40 AM
Quadcammer's Avatar
Quadcammer
was about to mention that also. Clutches were called out as being needed twice.
Old Sep 27, 2016 | 12:43 PM
EMBPilot's Avatar
EMBPilot
careful with that. "guidance" composed by someone with zero professional or accredited 993 technical background. just saying before you go installing that breather tube filter.
Old Sep 27, 2016 | 03:17 PM
Disraeli's Avatar
Disraeli
Roger that. The only thing I intend to do to my car is swap out the suspension after we start to thaw out next spring. The rest of the projects consist primarily of bringing it back to original showroom condition.
Old Sep 27, 2016 | 10:33 PM
New911's Avatar
New911
Definitely no clutches here.
In regards to mileage, I suppose it would have to be confirmed by some sort of record/carfax reading. We'll see what happens if/when the owner responds.
Old Sep 29, 2016 | 08:54 AM
pp000830's Avatar
pp000830
Sour grapes about not coming up with the the Home Depot breather solution yourself? I can send you one for your car if you like!
In good fun!
Andy
Old Sep 29, 2016 | 08:56 AM
pp000830's Avatar
pp000830
Since my reading skills have declined....
Old Oct 1, 2016 | 11:01 AM
Sagres74's Avatar
Sagres74
Veteran: Coast Guard
Be aware that Carfax is only as good as the honest individual entering the data, otherwise it's GIGO (garbage in, garbage out). Also keep in mind that not every shop/dealer feeds into Carfax, meaning that a lack of Carfax info doesn't necessarily equate to poor maintenance/history. It just means you'll need to find the records some other fashion. Best of luck!
