993 Forum 1995-1998
Speedo Calibration
Old Sep 22, 2016 | 01:14 PM
Allen's Avatar
Allen
When I replaced my speedo gears many years ago, I had to remove the speed needle. When it was time to re-install the needle...there was no "notch" or "key" to line up it's position. So I installed it, left the gauge out and went for a drive with my GPS speedo. I got it real close...60mph indicated, about 58mph actual. But I've always wondered how everybody else did theirs.
Old Sep 22, 2016 | 01:18 PM
Allen's Avatar
Allen
Originally Posted by Rick-A-Shay
Gas gauges seem drop faster after 1/2 then from "full". I was told once (in humor, I think) that besides a "low" reserve, there was a "full" reserve. Seems believable!
The gauge does indeed go faster on the 2nd "half" of the tank. I'm pretty sure that's just a mechanical trait with the float in the tank. The float doesn't actually start to move down until a couple (??) of gallons is gone. I don't know this to be true, but I suspect it is.
Old Sep 25, 2016 | 10:32 AM
JPS's Avatar
JPS
I did see a post here some time back with a gizmo that electronically adjusted the reported pulse by a percentage you determine.
