993 Forum 1995-1998
Custom Dials (tachometer) Recommendations?
Old Jan 21, 2019 | 01:52 AM
DutchNy's Avatar
DutchNy
Im looking a red face for my Tach only.
Old Jan 21, 2019 | 02:33 PM
skyboy's Avatar
skyboy
I got mine from the aforementioned http://www.heiler-tachodesign.de/.
It isnt installed yet but it looks like a quality item. I read somewhere they lack diffusers so I don’t know what it will look like at night,
Old Jan 22, 2019 | 05:35 PM
DutchNy's Avatar
DutchNy
Pic when you install them please
Old Jan 22, 2019 | 05:52 PM
skyboy's Avatar
skyboy
Heres the overlay. I’ll post pictures when I get it in. I want to do LED while I’m in there so it might be awhile.
Old Mar 10, 2019 | 10:12 PM
skyboy's Avatar
skyboy
Here’s an update on my project. Because I wanted the additional contrast of a white needle/pointer, I decided to get another tach so I can easily return to stock if desired. I struck up a conversation with the seller and when I explained my project he offered to paint the needle white for a very reasonable fee. Here’s the tach with my red face on it. Also visible in the frame is my highly technical needle removal tool. I used a compass to measure the distance to the first hash to get the correct alignment.
LED’s from superbrightleds website are in transit. When I make progress I will post. I should have taken a picture with the face off - there’s tons of room in there to add more bulbs if someone wanted to do that. The cunning eye will notice the bezel is not all the way back on. I will first see how the LED lighting looks before fully reassembling everything in case I want to go back in and add more lights.
Old Mar 10, 2019 | 11:46 PM
DutchNy's Avatar
DutchNy
Originally Posted by SuperUser
I have two red ones that I have been meaning to sell. PM me if you're interested. Never mind I see you wanted white:-)
PM sent, I’m looking for a red one
Old Mar 28, 2019 | 02:00 AM
skyboy's Avatar
skyboy
The project is nearing completion so it’s time for an update. I did the LED conversion to all the lamps, including warning lamps. Actually, I ran out of red ones so I’ll pop the clock out when more arrive. What I found was some pretty bad hot spots on the tach.
so I decided to go ahead and add more LED’s since I noticed there was plenty of space to do so.
I ended up adding 5 more after doing 4 and having a dim spot at the 2.
The procedure is easy. Using a battery tender as a power supply, I first determined the polarity with the two LEDs installed in the factory location. I noted the positive and negative with a pencil on the pc board. Then I soldered wire right onto the bus, taking care to place the solder joint on the end of the trace that would not interfere with removing and installing a lamp in the future.
Then i determjned thr polarity of the lamps I used and marked the positive side with a pencil. These were attached to various points with a hot glue gun. Then it was a matter of soldering leads to connect them all. I reassembled, found the cold spot for the 2, cried a little and took it all apart to add a 5th light, and put it all back together again. Tested, rejoiced, and then installed the tach back into the dash.
Final footnote about the LED colors. I use the coolest white offered for all. You can see the tach white looks different from the other gauges white and that’s because the overlay is not oem and I went with black in day because to me it looks more sinister, which I like.
in real life the while on the oem gauges doesn’t look as blue as the pictures. To my eye it just looks like a very crisp white and way way nicer than the old newspaper white of the oe incandescents. This upgrade is a must-do in my opinion. I also did the dome light, and the little light that shines down on the ignition. It really modernizes the car.
Old Mar 28, 2019 | 02:04 AM
skyboy's Avatar
skyboy
I forgot to mention, the final step for me is to put polished trim rings around all the gauges once I double check all my warning light work right and I clean up the dash of fingerprints and the grease they put on the rubber surrounds. If I think of it I’ll post a picture the final product.
Old Apr 23, 2019 | 12:12 AM
skyboy's Avatar
skyboy
Old Apr 23, 2019 | 12:17 AM
skyboy's Avatar
skyboy
Wanted to mention that I had replaced all the warning lamps with LED except the airbag light because I read that the circuit relies on the load of the incandescent to know if the light is working.
i had problems with both the immobilizer light (stayed on all the time) and the CEL (flashed very rapidly and presented a 1691 code related to not being able to “see” the light. Returning both to regular incandescents solved the problem.
Old Oct 23, 2022 | 01:49 AM
adamae82's Avatar
adamae82
3rd Gear
Hi Emissary, I’m very much interested with the RWB face. Can you please share on how you were able to get it done. TIA.
