993 Forum 1995-1998
Champion RG5B
Old 08-01-2016, 05:17 PM
GBX
GBX's Avatar
Default Champion RG5B
Just came across a set of Champion RG5B's for sale. They're 18x8.5 & 18x10 but the seller doesn't know the offset. Based on the below pic of these wheels on his 996, is it safe to assume that they will fit or is that too big of an assumption?
Old 08-01-2016, 05:23 PM
KeninBlaine
KeninBlaine's Avatar
I had a set of 19" RG5B's on my 997 C2S, and they looked fabulous. If I remember correctly, the size and offset info is stamped on the inside of the rims. They are GREAT wheels, strong and light weight.
Old 08-01-2016, 05:30 PM
GBX
GBX's Avatar
yes, I love this wheel but they don't make them in 18in anymore. This could be a great find!
A few more pics...any idea how to confirm they're real and not replicas? Are the recessed valve stems the way they came from champion?
Old 08-01-2016, 05:39 PM
KeninBlaine
They look like legit Champions to me. I don't remember the recessed stems, and my photos aren't close enough for me to compare them. The first photo seems to show something on the outer rim. Just beware that if the polished aluminum recessed areas get scratched, nobody I could find can restore the same level of polish as the original wheels. They will still look good, but the polish will be a little hazier.
Old 08-01-2016, 06:28 PM
GBX
GBX's Avatar
good to know. Thanks. Thoughts on what they're worth in this condition?
Old 08-01-2016, 06:30 PM
Nurburger
Nurburger's Avatar
They look like cheap replica's to me... If they dont have specs on the outer edge of the inner lips of each wheel, walk away.
Old 08-01-2016, 06:47 PM
GBX
GBX's Avatar
what cues make you think that?
just found some pics of replicas. On the replicas, the valve stem hole is a notch (u shaped cut out), not an actually hole thru the face. I think these are real.
Replica: Notice cut out for valve stem:
Old 08-01-2016, 07:46 PM
Nurburger
Nurburger's Avatar
I know my wheels.
I've owned several sets of RG5 and RG5B's. Just ask to see the Champion markings as noted before - if they are there, then I will stand corrected. I believe that Champion marked all of their wheels with a logo, size & offset info.
Old 08-01-2016, 08:38 PM
GBX
GBX's Avatar
Got it. Thanks for the heads up!! Will keep everyone posted.
Old 08-01-2016, 10:27 PM
NYC993
NYC993's Avatar
it's on a 996 for a start....
Look at the wheels in this post...bolt spacing, "forged" and size markings, stem...
https://rennlist.com/forums/997-foru...19-wheels.html
And offsets can be measured with a ruler.
Old 08-01-2016, 11:20 PM
GBX
GBX's Avatar
Thanks!! Very helpful. Probably explains why he hasn't gotten back to me yet with pics of the markings.
Old 08-02-2016, 01:28 AM
KeninBlaine
Just noticed that in the photos of my RG5B's on my last 997, the (faux) bolts around the outside are not even like the ones in your photos. There is 1 between the 2 close spokes, and 2 between the 2 spokes that have a bigger space. See photo below. So I think Nurburger is right. Too bad, as these wheels are hard to find.
Old 08-02-2016, 08:35 AM
GBX
GBX's Avatar
Yes, just wondering if maybe 18's were a different deign. Can only find pics of 19's. Let's see if the seller ever gets back to me.
None of the bolts are real, right? These are all 1 piece forged wheels. The b's are made to look like 3 piece with the bolts.
Old 08-02-2016, 08:41 AM
KeninBlaine
Correct, the "bolts" are not real, as they are 1 piece forged wheels. I'd be surprised if the wheel design was different for the 18" version.
Old 08-02-2016, 10:36 AM
Mark in Baltimore
Mark in Baltimore's Avatar
Took me a while to find the thread, but I think those wheels are Highline wheels. If true, they are cheap, eBay rims.
https://rennlist.com/forums/993-foru...ew-wheels.html
Quick Reply: Champion RG5B
