993 Forum 1995-1998
Quick question, will 285 30 ZR18 on 18x10 ET65 fit on my NB?
Old 07-26-2016, 08:10 AM
Bill Verburg
Bill Verburg's Avatar
This car w/ 235/40 & 285/30 MPSC on oe Speedlines needed the drivers side rear fender lip modified, as did several similarly setup 993s that I have seen
to those that run wider rears w/ stock fronts, understeer increases whether you feel it or not, if that's what you want fine but most want less understeer
Old 07-26-2016, 11:01 AM
Opo
Opo's Avatar
285's left - 265's right
YOU CHOOSE 😱🙄😂😂😂😂
Old 07-26-2016, 11:37 AM
Kein_Ersatz
Kein_Ersatz's Avatar
OPO for the win!
Old 07-26-2016, 12:12 PM
rg0115
rg0115's Avatar
BTW, will 235/40/R18 fit in the front?
Old 07-26-2016, 03:39 PM
Kika
Kika's Avatar
same caveats apply as above. the answer is a definite maybe.
Old 07-26-2016, 07:08 PM
shadow993
shadow993's Avatar
Originally Posted by Opo
285's left - 265's right YOU CHOOSE dde31dde44dde02dde02dde02dde02
Love it and agree 100%
Old 07-26-2016, 08:21 PM
TJ993
TJ993's Avatar
Default 235 40
They are fine on my 97 NB
I am using 265 40 now worked well and Fit the wheel wells]
Last set was 275 35 No issue fyi
If u r Matching Front Super Sports - Check the DOT Production Dates before you match up New Rears - I read here recently Super Sports are on their way out??
I do not let my date go past the Sixth Year
So if you have fresh and Deep Fronts you may want to aquire Two Pair of Rears
Old 07-27-2016, 02:12 AM
rg0115
rg0115's Avatar
Originally Posted by TJ993
They are fine on my 97 NB I am using 265 40 now worked well and Fit the wheel wells] Last set was 275 35 No issue fyi If u r Matching Front Super Sports - Check the DOT Production Dates before you match up New Rears - I read here recently Super Sports are on their way out?? I do not let my date go past the Sixth Year So if you have fresh and Deep Fronts you may want to aquire Two Pair of Rears
Thanks, is your 97 lowered? I am running bilstein b8 with HR springs. It looks like I would have no issues with the fronts using 235/40s?
Old 07-27-2016, 02:19 AM
rg0115
rg0115's Avatar
Btw, I did test the 285/30 on my car and didn't notice any rubbing, but I also didn't drive it hard as it has a nail in it. Is there an easy way test if I will have rubbing issues. Hard to tell by eyesight as I am not really sure how low it would compress under hard driving or going over a bump. Maybe lift the car and put a brick under the rear tire? Any suggestions on how to confirm rubbing without taking it for hard drive?
Old 07-27-2016, 08:52 AM
shadow993
shadow993's Avatar
Few ideas...
Jack the other side, so that's the other rear tire has a heavy load.
Easiest solution and most enjoyable... Go hit a few hard turns. :-) :-)
Realistically, if you have upgraded suspension you should be able to tell if it's going to hit anything. Remember the wheel tilts in slightly when going up when you drive. You also most likely have Negative camber on the rear as well, so it will miss the edge.
Just drive it and listen for noise and look afterwards then drive harder.
Old 07-27-2016, 12:57 PM
Edward
Addicted Specialist
Edward's Avatar
Nothing to add here, and looks is clearly highly subjective but I personally find it hard to argue with this stance
Along with their natural beauty, add in the facts that the Cup IIs are lighter overall, much less costly with every tire replacement, and on the street give up nothing in handling to wider 18s (where the 18s will even add understeer, yeachh!). For me, the only 18s I'd consider swapping with are the MY 02; otherwise, Cup IIs just look so classic and right (when the car is at a "proper" height as it is here). Just sayin
Edward
Old 07-27-2016, 04:27 PM
rg0115
rg0115's Avatar
I like the cup IIs and I agree with some of what you said. But the turbo twist for me just look much better. Just perfect for those lines of the car. I am keeping the Cup you never know, one day I might just mix it up again here and there
Old 07-28-2016, 01:00 AM
Edward
Addicted Specialist
Edward's Avatar
No arguing with a beauty like that
Edward
Old 07-21-2018, 08:56 PM
jk83
Cruisin'
jk83's Avatar
Sorry for digging this back up but what width and offset front wheels did you have please?
Old 07-23-2018, 07:55 PM
Allen
Allen's Avatar
No apology necessary...It was good to again see all the nice cars in this thread...especially Opo's comparison of the 285 vs 265...
Quick Reply: Quick question, will 285 30 ZR18 on 18x10 ET65 fit on my NB?
