Bumperette Delete 2016 style
Originally Posted by E30M3
The FVD duct lamps are designed to be plugged into the Foglamp wiring harness and what I did was replace the bulb with a LED 16 smd FESTOON bulb...
As for where the hole goes, it can be left to be merely cosmetic, or it can be fitted with a hose and used to route air to either the A/C condenser, front brakes or an aux. oil cooler I think? Perhaps someone with more knowledge can chime in...?
Thanks for all the info guys...
FYI after some more research, FVD sells their version of the Turbo S scoop ducts for $221 for BOTH pair; Carnewal is $100 more, and FVD sells the clear longer side lenses for $79 for BOTH pair. Suncoast sells the exact pair for $200, and says they're made by FVD on Suncoast's web page!
So, doesn't make much sense to buy from Carnewal and Pelican/Suncoast, as FVD sells the all parts for nearly half the price!
Thanks for all the help guys
Hard to see from that photo....would love if you'd share another pic when you have a moment....
1 Post
I finally made it home last night and was able to take a photo of the FVD signals. IMO, the gap between the signal and fog light (original to the car and likely never removed) is too large. At least I can finally spray the bumperette inserts this weekend...
One item to add to your list when doing the euro clear turn signals are bulbs. You can't re-use the clear bulbs from your old lenses because it won't flash amber through the clear lens.
The bulb is an #1157A available from any auto parts store. I put them in and didn't like the way they look (you can see them in my post above). It looks like an orange blob behind the lens and ruins a nice clean look IMHO.
An option are silver bulbs that glow amber when they are on. I sourced these from Fleabay for $13:
http://www.ebay.com/itm/182089579769?ul_noapp=true
Nice and stealth behind the clear lens...details, details
