Trouble With Tramont
As a guide, I'm running a 10jx18" ET59 Speedline Daytona c/w 265/35/18 Bridgestone S-02 at RS ride height. Geo is a fast road setup and all I needed was a gentle roll of the arch for full compressed clearance.
Your offset is just 4mm more aggressive on a higher suspension setup. Get the car to a garage/workshop that understand suspension geometry and I'm certain they will be able to set the car up and are likely to know someone if the arches need tickling.
C.
C.
Okay...
I measured bead to bead. The wheels have 9Jx18 ET52 cast in them.
Tramonts are 18x10 with a 55mm offset.
I'm running 265/35/18 Pilot SS tires.
As noted, I screwed up. Tramont sent the right wheels; I thought I had 10" wide rears from the factory. Since the new Tramonts were wider than my factory rims, it followed that they were 11" wide.
Also I used the factory wheels as the basis for determining fit and proper ride height. Since they were 9" wide, it threw things out of whack when I mounted the 10" wheels.
1) the old wheel front space was 75mm the new 84.7mm, f/s is bugger due to extra width and different ET, this means that the wheel outer face sits 9.7mm more outboard. The bead moved out the same and thus so did the tire sidewall.
2) the 10 stretches the nominally 265mm tire more than the 9 did. a Pilot SS when mounted on a 9 will measure ~10.5"(267mm) section width, the same tire mouted on a 10 will measure ~10.9"(277mm)
I've run much lower than you guys are w/ 10ET52 and 265/35 x18 w/ more aggressive camber(-1.9) and a bit off a fender roll particularly on the left rear.
1 Post
Camber is at factory recommendations.
I thought the wheels I removed were what the car came with from Porsche. To ensure I wasn't a complete loon, I just checked the owner's manual. Yep, 18x10's on the back; no mention of an 18x9 option anywhere. My COA says the car came with the 18" Technology Design wheels. Perhaps the wheels were swapped at some point, for some unknown reason? Wish I knew because the mystery swap is giving me a headache for the second day in a row...
1 Post
BTW, I'd like to offer a sincere thanks to all for the input. I began the day thinking I had a mild disaster on my hands but the wisdom of the group turned things around to where it looks to be a minor bump.
I'm darned happy with the new wheels again. I think those, combined with gmorat's bumperette inserts really transform the car. Gratuitous before and after photos -
You definitely have some options to make the rear wheels clear. Just depends which route you want to take.
- Change tire brand but use the same size. Identical size tires made by different companies have different section widths and will fit differently where the tread meets the sidewall.
- Add negative camber
- Roll the rear fenders
- Machine material off from the mounting pad of the wheel
Received 1,082 Likes
Car looks beautiful with either set.
I remember seeing your car advertised for sale a couple years back, glad you could keep it! I noted at the time your car had option code 408, or "technology" wheels (hollow spokes). As your car currently has 7.5"/9", then someone definitely swapped the factory equipped 8"/52ET and 10"/65ET wheels at some point. Unfortunate as they're not that easy to find, particularly the rears.
As noted, car looks grea with either wheel set installed. Hopefully you can find the ideal ride height/alignment setup to make them work without any rubbing.
I'm not sure if it's the angle of the pic, but do the rears appear overly aggressive and disproportion vs the fronts? Maybe after all is sorted with your rubbing issue you might need a small spacer for the front.
A couple of points.
Just increase neg. camber only works if you don't care about tire wear.
The position of the wheels relative to the fenders from an appearance standpoint is a personal matter, for me you get the ricer look if you do tricks like rolling fenders and running a lot of neg. camber to allow pushing the wheels out as far as possible.
You can replace the outer barrels and it isn't that difficult. I had one damaged in shipment and replaced it, Tramont sent me the procedure.
Tramont is a first rate company and Christine is great to deal with, I hope you have made things right with them.
